jwilson56
Well you know us Cocooners.....
I am working on switching over to use Comcast DTA's in front of my SageTV server's PVR-500 card using a USB-UIRT and two zones. The snag I ran into and didn't anticipate (I have not looked at the card in years since I installed it) was that there is only one coax to feed both tuners. So I am thinking of looking into the possibility of trying to make a hardware modification to split the tuner inputs into separate coaxial inputs by using the FM coax that is not being used in my setup to feed two DTA's into the PVR-500. Not sure it it is possible yet. I have an electronics degree so I don't mind doing some soldering. I just wanted to know check to see if anyone has seen a mod like this or had any experience before I take it apart.
