Wireless video?
dos46
All 4 bullet cameras are run to a DVR and a seperate monitor (viewing station) which is located in the back of the house in the garage. It will be extremely hard to run a catx cable from there to the main viewing TV (about 25feet away). Is there anyway I can transport this signal wirelessly from the DVR to the TV (plasma)? The DVR is capable of 480 lines of resolution (not HD).
They sell wireless video extenders, so it shouldn't be an issue. Just keep in mind that if these are indoor cams, you might not want to use wireless, since it might allow other people to snoop on you while you are in the comfort/privacy of your own home.
Do you have any cabling out there? You could also modulate it onto a channel on the Coax if there's access to that anywhere in the vacinity.
These are outdoor only so that shouldn't be a problem but thanks for letting me know about that potential problem.
Use an RTSP streaming server such as Helix with a video capture card and shove it over the network. You could do wireless if you don't have a network cable out there, just make sure you have encryption turned on. View with VLC, WMP, Quicktime, or an iPod Touch/iPhone/Android phone.
