Hi-
I spent a good part of last evening planning out how to connect the following three items to the M1:
Now after doing the math, and reading the instructions that come with the Elk M1, it sounds like all of the alarm outputs have a combined max of 1 amp. Adding up these three items, in full alarm, I'd be pulling about 2 Amps.
Now to a few questions that maybe someone can help with:
Thanks everyone for all of your help. I can't say enough about how great this site is for learning about all of this - hopefully once this is all done I'll be in a spot where I've learned enough where I can help out others as well.
Thank you!
- 150RT Siren (1.2 Amp draw, 6-14 Volts)
- SS15 Siren (550ma, 12 Volts)
- SL1 Strobe (210ma, 12 Volts)
- Knowing what we know about Output 2 (1A max) plus the draw of the Elk 150RT (1.2A), what's the best way to wire this siren?
- For the strobe, I'm assuming that relay on Output 3 is the best option. I have motions/glass breaks installed that have a combined draw of about 400ma in full alarm (by spec, I haven't load tested it yet). Will I have enough power to use the Auxillary power on the M1 to drive the strobe (200ma), and use Output #3 to activate it?
- Assuming that Output 3 is the best option and that there's enough power from the aux power, how do you wire the strobe to pull power and activate through Output 3?
Thank you!
