Zone Rule Trouble
Trying to bypass an exterior door in my Elk M1 on a certain day between a certain time.  The zone is set to "Burglar Perimeter Instant" and below is the rule I have for it but it is not working.  What am I doing wrong?
It looks to me as if you're trying to bypass the zone after the area is already armed.
You need to bypass before you arm.
Remove the first line and make the second line the trigger
Whenever days of week.........
     And ....................
         Then bypass.................
Still having trouble with this...
You can't set the whenever rule for a specific day of the week.  All I can do is
Whenever the time is 3:00 AM
And the day of the week is M
Then bypass zone XX.
Am I correct in thinking that this will only bypass the zone when it is 3:00am?
I may have misspoke using day of week as a trigger, I should have checked available triggers. Using the time as a trigger then the day of the week as a condition should work, though. Often there can be several ways to obtain a desired result.
What you have will bypass the zone at 3:00AM only on Monday. Any other day of the week the zone will not bypass at 3:00AM
Will it stay bypassed or become unbypassed at 3:01AM?
