Hey Guys, i have found lots of useful information on this site through searches but also quite a bit of difference in opinion.
My situation, we are building a new house - nearing the finalization of house plans so still early. I Have bought an elk m1G with m1xsp, m1xzw, and the Ethernet interface for the purposes of:
- Security
- Lighting control
- hvac control.
I have plenty of other home automation and AV plans but sticking to the above for the moment.
QS1) The house we are building will have Milgard vinyl double hung windows. After all the searching i have seen a whole lot of mount and sensor choices, just not one that stands out as a best use item or a best case way to install. Additionally there seems to be many differences opinion on wiring one sensor per zone vs serialzation of sensors on a window set. So my questions are:
1) Is there a preferred contact for vinyl double hung windows or is it anything goes? What about a preferred style of contact type? mfg?
2) I know keeping sensor contacts isolated vs serializing them adds debugging resolution - but whats the generally best way serial or individual ? (assumes NC contacts)
3) Example schematics oh how others approached their new houses would be great.
QS2) Lighting control - seems like there are many solutions here as well, I was contemplating the zwave for a number of reasons and even bought the zwave elk module. I am concerned that there seems to be a lack of response in getting a true status of what the control device is at. I also see many messages about not using the elk zwave interface but using something like vrcop. I think zigbee would be a better choice then zwave but it looks like that product is no where as far along. So my questions here are:
1) What really is the best technology choice for reliability and ability to know what a devices current status is, give this is new construction?
2) If Zwave should i dith the elk zwave interface in favor of something like vrcop?
QS3) HVAC - the home specs include a EWC 3 zone controller and Honeywell Visual pro 8000 touchscreen Thermostats. It doesnt look like they are connectivity compatible. From what I have seen of the few thermostats supported by ELk which were april aire, RCS and HAI, i like the omnistat 2 the best. All these options seem pretty expensive, he furnace we will have is a lennox mvp61 - that's a 2 stage variable speed. So my questions are:
1) Any recommendations on Thermostats? Experience with Omnistat2 or thermostats not mention that I should consider.
Thanks alot in advance.
- Security
- Lighting control
- hvac control.
