I have a question about possible future capabilities of the Elk M1 as far as allowing integration with Third Party Developer applications. I would like to develop an application which would run on a separate server or “cloud” which would take as input a trigger from the M1. It appears that the current capabilities of the M1 are to send an email (which is limited to 10 separate emails) or text out a serial port.
Assuming the M1 has the M1XEP is it possible to send a different type of external trigger from the M1G system? An ideal scenario would be a URL open. So for example if a zone changes state the M1XEP opens a URL http://X.Y.B.C/myapp/resourcePath?queryParameters&key=OpenDoor
This would allow limitless possibilities for integrating the M1 into modern web based servers such as IFTTT.com that offer REST Apis
Another way to think of it would be, I would like to write a python application that will listen for status changes from the M1. I do know that I could log into the M1XEP and listen to the serial stream. This seems to be limited since it would disrupt local uses controlling the M1 from eK M1 iPhone application.
Bottom line, can anyone comment on if/when/how Elk plans on allow integration into modern development platforms? Imagine having the ability to use IFTTT.com with your Elk system and you can start to appreciate what could be possible.
