So on my Windows 10 machine, I can't get Elk RP2 to connect to my M1XEP on my LAN with nothing other than a switch between my PC and the M1XEP.
I see TLS errors each time that I try to connect. My M1XEP has the older firmware that still has the Java-based website, and while it'll start running the Java Applet, it throws an error that it too fails to connect. I shut down my firewall just to rule that out. I'm wondering how far I should dig into this, and if anyone else has tried this...?
If you have a Windows 10 machine, are you able to connect to the M1XEP using the latest build of Elk RP2?
Thanks!
Thanks!
