Sure. I've been using NextAlarm for years, but there are others. NextAlarm and Alarm.com tend to be the companies people use.bdAZ said:Hi All -
Quick question: Can a HAI Omni IIe system be monitored by a central station via an Internet Connection (preferred) or VOIP connection?
Any recommendations on monitoring companies to use?
Thanks kindly.
If no adapter is needed how do you connect the analog phone connection on an Omni to the Internet? If your saying it goes over regular VoIP (assuming you have that) what happens if your on the phone when the Omni wants to communicate?drvnbysound said:I've used and recommend AlarmRelay. I've setup multiple people with their service with Elk systems - no special broadband adapter was needed.
ano said:If no adapter is needed how do you connect the analog phone connection on an Omni to the Internet? If your saying it goes over regular VoIP (assuming you have that) what happens if your on the phone when the Omni wants to communicate?
Bad idea. Many reasons.ano said:Sure. I've been using NextAlarm for years, but there are others. NextAlarm and Alarm.com tend to be the companies people use.
You will need to buy an broadband adapter like this: https://info.nextalarm.com/shop/
They are maybe $70. Plug the Omni into it, and plug in the Internet, and your ready to go.
OP has an Omni IIe.drvnbysound said:Not sure if you followed all of what I wrote, but I'll clarify. I've used AlarmRelay with Elk systems (not HAI) - with the Elk XEP (Ethernet module) which essentially makes the system network-able. With this device, in the Elk eco-system, the CS is able to monitor the system without any additional modules. The CS literally monitors via IP traffic - no analog (or VoIP) phone.
ano said:OP has an Omni IIe.
DELInstallations said:Pull the network cable from the modem and tell me if the ATA ever lets the panel know there's not a viable connection. It won't.
They make a tiny UPS for this here: http://www.amazon.com/APC-BGE70-Back-UPS-3-outlet-Uninterruptible/dp/B00KH07WRCStarTrekDoors said:Also, if using an ATA, remember to put your ATA, network switch, network router, and DSL modem/cable modem/IAD/ONT on UPS as well, because all will need power to continue operation during a power outage in support of VoIP.
I would agree that is a tiny UPS which may be too small to support all the network equipment depending on the load and how much runtime is desired plus that model's output is square wave, so can cause some issues with sensitive electronics.ano said:They make a tiny UPS for this here: http://www.amazon.com/APC-BGE70-Back-UPS-3-outlet-Uninterruptible/dp/B00KH07WRC
DELInstallations said:Spend for an IP communicator or go straight cellular only.
http://www.securitysales.com/article/alarm-company-s-carelessness-costs-customer-her-life
8 digit settlement for installing a cellular backup on a VOIP phone line. Never functioned.
No, if you have a rack of equipment, then this UPS wouldn't be for you. For my switch and alarm IP adapter it runs about for 4 hours. I also have a APC BR1500G for my Mac Server. With NOTHING plugged in that will run MAYBE 90 minutes. Its certainly not designed for long operation.StarTrekDoors said:I would agree that is a tiny UPS which may be too small to support all the network equipment depending on the load and how much runtime is desired plus that model's output is square wave, so can cause some issues with sensitive electronics.
We generally recommend the APC BR1500G as a starter size UPS unit to have enough outlets, decent run time for long power outages, and the BR1500G approximates a sine wave, so won't damage electronics plus you can add expansion battery packs as well.
A good UPS will also allow you to power your Omnipro, your PoE switch that runs your cameras, touchscreens, etc...., and everything needed to support your VoIP and/or cellular installation.
