Hi guys
I been using this panels just for a over 2 years n i been stock on the cameras section, one day learn something the next a little bit more , till now
Question: have some out there make work and ip camera and enable to see it on the smart phone (android) ?
I did , but im at the point to be enable to see it just when im on the wifi, (local), so if im connected on the same network i can see the cameras, but if i connect to my static ip , no i only see a black screen (remotely and do anything )
so here is what:
panel omnipro II
ip camera 4mp by Hikvision dual straming (mjpeg) programmed for 2nd stream as mjpeg
Nvr by hikvision
internet provider Comcast
so my Nvr, cameras and omnipro are on the same network, adding a poe sw for the cameras ( the nvr is poe build in , but im not using his internal netwotk) so all the cameras has different internal ip , on the pc acces i did program they address with the url (the one was so hard to found it , also im using the nvr to have recording and because they are all on the same network the nvr can see
so what i learn was the problem is to found the url stream line
do any one knows what else i have to do in order to see it over the snaplink not on site?
best regards
Armando
so here is what:
panel omnipro II
Nvr by hikvision
best regards
Armando
