DELInstallations said:The Ditek, via 12AWG would be my suggestion. How you get it to the rod and protect it from physical damage is another consideration. Could do compression to the grounding conductor, but definitely bypass the load center portion.
Best case scenario is to the ground rod and to the same connection, cad welded or similar, but usually neighbors don't like it when you do that.
That's al doable. I never heard of cadwel before so I looked it up on youtube and it looks fast neat and solid but connecting to the ground rod is not my worry,
I'm trying to avoid installing yet another enclosure on the wall and cutting another splice in the rs-485 for such a small device as the Surge protector and the Elk can seems a likely place for it. What makes it so difficult is that the elk can is at the top of the basement staircase built into the wall and it's a pretty long run to a ground stake.
On the garage end it will be pretty easy for me to clamp the Ditek to the awg6 that is grounding the load center to a ground rod in the earth but the house end is a little more difficult.
