CAI_Support
You might be able to switch 300 lights if using BCD decoding for those output pins. If switching on all the light together, would that cause a little power surge? I suppose you can do that with ALLOUTS. For 8 bit board, 8 TTL output bit can be BCD encoded to control 2^8 = 256 lights.
todster said:I have about 300 zones of flourescent high bay lighting that will be automated in the near future. The lights will be switched with SSR's so they switch at the zero volt transition. Anything I can do to reduce the number of boards needed to control this would be a plus.
I wasn't especially set on using that, it was just an example. The other problem is the W/C wouldn't be able to power all the relays at the same time?
