ddennerline
I wish Elk would correct some current deficiencies and add a few other features. Some of the items below can be worked around using some custom engineered solution. Having a less expensive solution, both in time and money, is attractive.
- Variable level voice. When it’s dark out-side, set level to 25% for non-alarm messages. I still want to be notified when my front yard detector goes off at 3AM in morning.
- 100% accurate lighting solution whether it’s UBP or ZWave. The M1XSP/VRC0P integration does not support all Z-Wave command classes. It doesn’t support scenes. It doesn’t support low-priority polling.
- Support for humidity sensor (actually a temp/humidity combination)
- Accurate temperature support. It was extremely cold this week, the Elk-M1TZS stats were off by a large margin. I know that I can “tune” them, but I don’t understand why they leave the factory without being properly calibrated.
- A reasonably priced (under $300) multi-line display keypad. A screen large enough to display important factoids such as current time, outside temperature, tomorrows weather, and current system trouble (low battery on zone 1). It would be nice if screen had a close proximity sensor that would enable backlighting without having to fumble for buttons at night.
- Support for Z-Wave locks
- Support for logging all inbound/outbound data to M1XSP. Having to spend money to buy a SerialTap/RS-232 adds to system cost and reduces HA ROI. In general, more diagnostic tools.
- Support for larger set of substitutable fields in text and email messages
- Increase output 2 power to match ELK-45 1.2A
- A lower-cost Elk-WSV. The $430 almost reaches the cost of my homeowner’s deductible.
- Support for mounting ElkM1G directly to Leviton/ChannelVision structured wiring box
- A MagicModule that is capable of being plugged directly into M1G, is easily programmable using high level language, and fully supports Elk ASCII protocol.
- Support for named counters and triggers within ElkRP. It would be possible to add support for analog sensor types such a wind speed, gps distance, water volume, and pressure and be able to write rules using those inputs.
