My ElkRP knowledge may be lacking. Is there a method in ElkRP to display text on both upper and lower 32-character lines. I seem to only have been successful in writing rules that displays text on the bottom 32-character line. I currently have a set of rules that "billboards" text along the bottom 32-characters. I tried the scrolling text, but it wasn’t legible.
I cannot really afford the $1300 for Elk TS-071. A Honeywell CV-6272CV touchscreen keypad can be purchased for $278. The Honeywell device’s functionality is nowhere near what a TS-071 can provide, but I am living with my $142 Elk keypads – albeit I don’t like the small screen/low resolution.
The Elk 28” SMC still only has one position to mount ElkM1G as I remember. I want to be able to move things around if/when I change/add components. I really hated drilling into my 42” Leviton SMC (oh well).
You can mount the M1 in 3 separate locations in the 28, top, middle, or bottom, but it determines where you can mount the peripherals. I've been using the top in the 28" and using the bottom left for boards, right for full width units. You can use another manu's can, UL listed with the panel if you follow Elk's documentation, however you lose the advantage of being able to use the board slides and the slightly denser unit packing.
There's no comparison to Honeywell's equipment and Elk, especially the touchscreens, as you've noted, but the main thing is you're looking at a TS that goes up against TS's for other systems that cost 4 times the amount.
Let me know if you're looking for a TS, I probably have one or two from a demo around that I'd let go for less than the price you said.
