dementeddigital said:
If a circuit takes a differential mode surge across two wires (ignoring other possible paths for the moment), the clamping voltage of the transient protection device across them will dictate the voltage that circuit will see. Response time is important, as the edge rate of the transient might be faster than the transient protection can start to conduct.
First, transients that overwhelm existing internal protection are longitudinal; not differential mode. Protection from differential mode already exists; is quite robust.
Second, a typically destructive surge with a fastest edge rate is the classic 8/20 microsecond transient. Rising edge is microseconds. Effective protectors respond in nanoseconds.
Yes, response time is important. View numbers. Nanosecond protector responds more than fast enough even for the fastest (microsecond) surge. Once we include numbers, protector response time is completely irrelevant.
View other relevant numbers. Microsecond transients means impedance (not resistance) is critical. Effective protector means hundreds of thousands of joules must connect to and dissipate harmlessly outside in earth. A hardwire to earth ground must be short (ie less than 10 feet). No sharp bends. Response time is why low impedance is relevant. Connection to earth ground must be low impedance (ie not inside metallic conduit). That (and not a protectors response time) is critical.
Third, destructive surges are current sources. Voltage is a dependent variable. Independent variable (what is relevant) is current. A properly earthed 'whole house' protector must conduct an entire surge (ie a direct lightning strike) and not fail. Since lightning is typically 20,000 amps, then a minimally sufficient 'whole house' protector is 50,000 amps. Another relevant number once recommendations are tempered by numbers.
Effective protectors discuss how many amps will connect to earth. Ineffective protectors are rated by how much energy it will foolishly 'block' or 'absorb'.
So what is a worst and best solution? Undersized protector fails as indicated by its light. How many joules does it claim to absorb? Hundreds? How many joules must it somehow 'block' or 'absorb'? Hundreds of thousands. Protectors that 'block' or 'absorb' a surge means a surge voltage increases. Failure due to undersizing means a 120 volt protector exceeds 900 volts. That higher voltage is due to too many amps being 'absorbed' or 'blocked' by a plug-in protector. But failure gets many to recommend that ineffective protector. "My protector sacrificed itself to save my computer." Total bull exposed by numbers.
Excessive impedance means a plug-in protector has no hardwire to earth ground. Response time means impedance of a hardwire to earth should have full attention.
Informed consumers earth one 'whole house' protector to have a 'secondary' protection layer. Then inspect their 'primary' protection layer also defined by an earth ground on a utility pole. Every protection layer is defined only by earth ground.
Concern for voltage and response time is why effective protectors must connect low impedance (ie less than 10 feet) to single point earth ground. A protector is only as effective as its earth ground. Not any ground. Single point earth ground. Then robust protection already inside all appliances is not overwhelmed.
