dementeddigital said:
We can agree that a Type 1 or Type 2 surge protector is certainly the first line of defense. This thread also discussed long runs of data lines which leave one structure and go to another. A whole-house suppressor won't protect those. A whole-house suppressor also doesn't eliminate the need for Type 3 devices at sensitive electronics. It's good for big hits, but the clamping voltage tends to be higher than it is in the Type 3 devices.
First, Type 1, 2, 3, etc define human safety. It says nothing about protection. Since plug-in protectors are undersized, then the chance of fire increases when located in a Type 1 or 2 location. Numbers (that were ignored) makes that obvious. How does its hundreds or thousand joules absorb a surge that is tens or hundreds of thousands of joules? So Type 1, 2, 3, etc was created to make fire less likely. Fire is a serious problem with undersized (plug-in) protectors.
Second, appliance protection is never about 'Type'. Protection is always about how that protector connects to earth. If the discussion does not mention THE most critical item in a surge protection system - and with numbers - then the recommendation is best considered bogus.
For example, a SteveJenkins citation (
http://www.stevejenkins.com/blog/2014/10/whats-the-best-whole-house-surge-protection/# ) does not discuss earth ground. He makes no effort to describe what a protector really does. And he does not even know that 'whole house' protection already exists on cable, dish, and telephone as required by codes and other standards.
He mistakenly believes a protector does protection because hearsay and advertising say that. He does not even know of (discuss) the 'primary' surge protection layer. So much misinformation or human mistakes are posted that I hardly know where to begin. But again, surge damage is due to humans making mistakes.
Third, a direct lightning strike to AC wires far down the street is a direct strike incoming to every household appliance. Protection already inside appliances makes other, lesser surges irrelevant. A properly installed 'whole house' protector also makes those lesser transients irrelevant. But 'secondary' and 'primary' protection layers must exist to protect appliances and ineffective Type 3 protectors.
His first example was damage directly traceable to human mistake. He assumed that because nothing was damaged, then an incorrectly installed 'whole house' protector must have done protection. In reality, each appliances probably protected itself. We know this. He did not provide numbers. That burned 'whole house' protector was less than 50,000 amps - his mistake.. So it fried. That citation demonstrates why it failed. He ignores all critical numbers. No numbers is why humans make mistakes and are easily scammed. No numbers is also why that Type 3 protector does not provide effective protection - and are obscenely profitable.
Fourth, protection already inside every appliance makes a Type 3 protector unnecessary. If a 'secondary' protection layer (what was called Type 1 or Type 2) does not exist, or if a 'primary' protection layer does not exist, then superior protection inside appliances can be overwhelmed. Protection is defined by each layer's earth ground. He never once discussed THE most critical item in every surge protection layer - earth ground.
"Type 3" protectors have no earth ground. How does it do protection from typically destructive surges? It doesn't. It is for a type of surge surge that typically does no damage. And it must be protected by a 'whole house' protector. More numbers. A 'whole house' protector is defined in IEEE Standard as doing 99.5% to 99.9% of the protection. Those plug-in protectors may be an additional 0.2%. Why are expensive protectors also least effective?
SteveJenkins recommends some of the better 'whole house' protectors - part of the 'secondary' protection layer. But he does not say why. 'Whole house' protectors are provided by companies known for better integrity including Intermatic, Square D, Ditek, Siemens, Polyphaser (an industry benchmark), Syscom, Leviton, ABB, Delta, Erico, General Electric, and Cutler-Hammer. A direct lightning strike can be 20,000 amps. So a minimal 'whole house' protector must be 50,000 amps. Effective protectors do not fail even with direct lightning strikes. Protection is installed, first and foremost, so that direct lightning strikes damage nothing - not even damage a protector.
Fifth, dementeddigital details another example of human mistake. He all but invited a direct strike into the house. So a surge even conducted on used a drywall metal bead. His stereo suffered damage. No plug-in protector claims to protect from that type of surge. But it is called a surge protector. Only speculation assumed it might protect a stereo. Assumption does not replace knowledge with numbers.
Lightning rods protect the structure. 'Whole house' protection protects appliances. Both are only as effective as their earth ground. Because he did not earth lightning BEFORE it could enter, then a human mistake resulted in drywall and stereo damage.
Sixth, by ignoring spec numbers, he assumed the clamping voltage of 'whole house' protection is higher than plug-in protectors. Reality - both have a 330 let-through voltage. Meanwhile a hardwire that protects cable has a higher clamping voltage? Of course not. One must learn numbers (ie 330 volts) before making accusations. Actual clamping voltage of a 'whole house' solution is even less because it is connected low impedance to earth. What was the clamping voltage of his plug-in protector? Previously discussed with numbers. "That means a black hot wire is at 5000 volts. White (neutral) and green (safety ground) wires are now at 4670 volts."
Voltages at a properly earthed 'whole house' solution can rise to only hundreds of volts. Lower voltages are provided by properly earthed protection. Voltage can be higher if only using pljg-in protectors. Plug-in protectors do so little - maybe add 0.2% of the protection.
Seven, long runs of data lines which leave one structure and go to another are routine without damage. It exists in every town. In every location where long data lines exist, the 'whole house' solution is routine. Otherwise a lightning strike to one structure is a direct strike to appliances in the other. That is why your telco installs a 'whole house' protector for free. How many others (who made recommendations) even knew that protector exists? Why not?
Eight. Separation between protector and appliance also increases protection. Telcos want their protector to be up to 50 meters distant from the $multi-million switching computer - to increase protection. Note who actually knows these numbers due to learning the science as well as actual experience. Protection increases with separation between protector and appliance. Protection increases with less separation between protector and earth ground.
A protector is only as effective as its earth ground. So informed home owners spend maybe $60 for a 50,000 amp 'whole house' protector. The inspect a low impedance (ie less than 10 foot) connection to THE most critical item that does protection - single point earth ground. Best is to ignore silly nonsense about Type 1, 2, 3, etc protectors. That says nothing about surge protection.
Unfortunately so much misinformation exists that I hardly knew where to begin. We know that StevenJenkins article is not based in knowledge since he did not even discuss THE critical number for an effective protector - ie 50,000 amps. No numbers is the first indication of bogus recommendations and junk science reasoning. Plenty of questions should now exist. For example, what must be inspected in the 'primary' protection layer? We know why expensive type 3 protectors do so little. A protector is only as effective as its earth ground.
