DELInstallations said:
he telco protectors you tout as the cat's meow are self sacrificing....they shunt to ground or physically disconnect and shunt to ground.
A telco CO suffers about 100 surges with each storm. They replacing tens of thousands of protectors with each storm? Of course not. But that is what you have claim.
Everything weakens with age. So parts are sufficiently sized and properly earthed to survive direct lightning strikes even for decades. Unfortunately others here still do not get it. Protectors do not do protection. Earth ground does. Does not matter if you get it. Others foolishly remain attached to an advertising myth that protectors do protection. When numbers even demonstrate how high profit and near zero protectors can even earth a 4670 volt surge into adjacent appliances..
A sacrificing protector is ineffective. But it does have one desirable feature. It can report when a protector was grossly undersized (ineffective) for that venue. And defined a path that a surge took destructively to earth. Then overstressed component can also be identified and replaced.
Why do we need to know your emotional state? That does nothing for the OP, anyone else, or the topic. OP had damage in a detached garage and house probably because a 'whole house' solution was not properly earthed at both ends of every wire between that garage and house.
Obviously transorbs cannot be used on communication circuits due to parameters such as excessive capacitance. Transorbs have a lower "pass-through" voltage; not higher. Compromises - especially excess capacitance - make transorbs unacceptable for that application. Transorbs are used elsewhere such as on electric toilets. Since that protector - like all effective protectors - remain functional for decades even after hundreds of thousands of surges. When does a transorb degrade? When a naive tech does not first learn how to design with numbers.
Meanwhile, a transorb does nothing for the OP and his problem.
Like all protectors, sacrificing never provides effective protection. But sacrificing get the naive to recommend near zero protectors - and buy more. Undersizing a protector increases sales and profits. Then advertising gets the naive to recommend and buy more. Only the naive believe protectors work by sacrificing. About 100 surges with each storm. So you tell us each CO replaces tens of thousands of protectors after each thunderstorm? Of course not. Engineers designed the protection - not hearsay.
Protection is more than a Ditek. A Ditek, like any effective protector, is only as effective as its earth ground. If not properly installed, then its clamping voltage or response times can be excessive. The informed learn about impedance, equipotenial, GPR, metallic and longitudinal mode currents, where joules are absorbed, numbers that say what a protectors will not fail (sacrifice), and wny LV circuits are so robust (already have effective protection), You finally admitted that clamping voltages and response times are already more than sufficient for each protector. And that volltage and response times are mostly defined by how that protector is installed/connected. Protectors respond in nanoseconds. Surges do damage in microseconds, milliseconds or minutes. Again, those pesky numbers.
OP had damage both inside a detached garage and house. Classic damage when every wire is not properly earthed (directly or via a 'whole house' protector) at both ends. Apparently the OP had no properly earthed 'whole house' protector in a detached garage. That explains why he had damage in both garage and house. Even transorbs do not do what must exist to have protection - single point earth ground.
For those who need soundbytes to be informed: Properly sized and selected protectors never do protection by 'sacrificing'. Protection is always about where hundreds of thousands of joules are harmlessly absorbed. A protector is only as effective as its earth ground. Even clamping voltages and response times are mostly defined by that connection.
