CAI WebControl Logger [Software]
Hi, I have been working on the code for quite some time.
It has been quite a intense job since I have rewritten a lot of the code.
I have implemented a lot of logic that was not present at the first versions.
I have also struggled with a lot of VB issues, since the compiler has som limitations as is. (Scrolling, timers etc)
But I have now been testing v1.2.0 for quite some time.
It runs stable on my Win 7 computer, and logging seems to be ok.
There are also some hidden features, like auto saving of IP adresses used.
Here are some pic's of the new version:
That looks nice !
I'm looking forward to try it out.
I have another wish, is it possible to have an option with
user defined labels ?
To add a row in the last picture, for inputs and outputs where I can write ie. outdoor temp. boiler...etc
I hope you understand....
/S
That looks nice !
/S
Yes, I understand. You want to label TTL Input/Output Bits, Right???
I just have to add the function.
The settings for the labels can be written to Registry/Inifile, no problem.
The easyiest way, is to make a extra settings form where you put the inputs you want available.
Back to the drawing board...
Wow, you are a fast guy !!
If it´s not to much ask I would like to put lables to all psysical in/outputs and VAR 1-8.
/Staffan
Hi, I have added the function as a ToolTip text.
That way, the form is unchanged. I just added a settings form to get the text wanted in the tooltips.
I have to add the Var into the code...
Here is an example of how it looks:
Yes !
That is very nice, this is getting better and better :D .
This is something I have missed in WebControls GUI all the time.
V1.2.0 is uploaded.
Changes:
  • Added status Page
  • Added tooltip text option in statuspage
  • Added IP adress Autocomplete function
  • Added About form
  • Added multi scrolling function
  • Added LogON/off function
  • Rewritten a large part of the code, program loads faster, uses less memory
  • More userfriendly interface, including error control
Download: http://www.weatherby...y_view&iden=139
Hi Lars !
Thanks for the V 1.2.0 !
I have used it for some days now and I like it !!
Do you have any other updates coming ??
We talked erlier about the possibility to send/recive data between two WC-PLC:s,
is that possible ??
/Staffan
Hi, I have just flickered some on the code.
Not anything that needs to be updated.
To get the two PLC's to communicate I'm sure it can be done.
Excample:
IF PLC1 TTL 1 Input bits value = 1
then PLC2 TTL 1 Output bits value = 1
Any whishes for V1.3.0?
I have the code for implementing different languages, but I realy don't know if this is wanted.
Also, looking on the downloads, it seems like the followers is a small herd. (50 downloads or so...)
I have already implemented tooltip for the hum sensor.
I will not make a 2 plc version at this stage, since it demands a lot of programming.
And, I need two PLC's to debug all the problems involved...
Anyhow, any tips is welcomed!
Hey there, you have another follower, I'm really interested in this development and can't wait to try it out next week when I get my webcontrol back from CAI. The first one i got would not remember settings when power cycled. A new one is on it's way.
I am really interested in using the webcontrol to setup a garage door opener, irrigation controller and as 1-wire interface. I am deploying a number of 1-wire temp and humidity sensors (might have to use a different device for these) in my house.
What are the folks here using for front-ends to remote control the webcontrol, if anything - from an iphone? I was planning on using openremote, anyone have experience with it? I have it setup and it can send/receive HTTP commands and can easily query the webcontrol for sensor status and should be able to change the TTL bits, meaning a button on the openremote can easily switch things on/off like a garage door or light.
Cheers!
