Hmm... I have no clue why, but it seems like you have a problem with a dll or ocx file.
To debugg the problem I had to install VB6.0 on the XP Virtual Machine.
So, then I wont have the same problem.
A solution worth to try is to install VB6. SP1.
It contains a lot of the files you can be missing.
Download:
http://www.weatherby...=vbrun60sp6.exe
Install and try again...
And, check that system32 has the following files installed:
comdlg32.ocx
msinet.ocx
richtx32.ocx
tabctl32.ocx
comctl32.ocx
mscomctl.ocx
qprogif.ocx
If they are there try to check if they are registered:
Click Start type command "cmd"
Browse to system32 folder in cmd window
type regsvr32 comdlg32.ocx and check that file is registered.
Then do the same to ALL ocx files in the list.
