tadr said:I figured out the issue. I had one disabled zone that was still assigned to Area 2 that I completely forgot about it. Once I reassigned that zone to Area 1, I was able to delete Area 2 as expected and then "send all Areas." Now Area 2 is gone from the panel.
Although I feel dumb for missing this, some more informative prompts from Elk RP sure would be helpful.
Edit: Thanks for the help and patience DEL and Mike!
I personally think that ElkRP is due for an overhaul, it is a little primitive compared to modern software and now that we have Windows 10 I'm afraid that there will be some new problems with it. On the other hand it does a lot of work and I would hate to have to live without it and do everything through the keypad. It really is the true strength of the system.
Before spending a lot of hours troubleshooting a problem I like to start a new customer account and then receive my panel to that account. It takes a lot less time than I might otherwise spend trying to discover what is causing the problem and you can always just go back to the old customer account if the new one doesn't solve the problem.
I consider it a bug that RP will remove the area and leave behind a zone assigned to that area.
Mike.
