Megohm meter. Commonly used to find these sorts of things. There's things you can't take into consideration, but ground paths and insulation integrity are tested and certified often in mission critical applications.mikefamig said:Lou Apo
another question -
If lightning strikes the ground why would it travel into the building on it's earth lead to a piece of equipment and conduct current to the neutral in that device if that neutral is isolated from earth? I'm a little confused here. I can see the lightning traveling in on a data line and finding an earth ground but not traveling in on a ground wire and finding a neutral.
Mike.
Doesn't get done in a residential situation EVER. Closest I've seen to a megohm meter being used on a residence was post-Sandy and people attempting to salvage panels and cable because of hte insurers.
