It all has to be insulated or it will just become part of the primary wire.
That makes sense, didn't think of it that way!
Another possibility, if you have any UPB, is to use a UPB I/O device, e.g., the Web Mountain CM-01.
Sure. It was easy. I purchased two Veris Industries Hawkeye current sensors which are placed over the hot wire of the power cords. I did use a knife to split the washer and dryer power cord. Then I connected each of these to an ELK 960 timer, then to a UPB I/O module. You have to play around a bit with the timings and settings to correctly detect the end of the cycle. Most electric dryers cycle on and off quickly so the timer smooths that over. You may not be able to detect the exact cycle end but you can get within 5 minutes.gasbie said:sorry to bring this old thread ti life. was anyone able to automate their dryer or washing machine buzzer? if so, could you explain what you did. thanks
ano said:Oh, and I should add this is for an electric dryer. If your is gas, your on your own.
Mine works great. Your just measuring current. Motors draw current, heating coils draw current. As long as you can detect it, your set.RAL said:Even with an electric dryer, the motor is probably a better indicator of when the cycle is complete vs whether the heating coils are drawing power.
ano said:Mine works great. Your just measuring current. Motors draw current, heating coils draw current. As long as you can detect it, your set.
Unpermitted Work
If a fire is deemed to be caused by electrical issues in a home where the electrical work was not permitted by the county in which the home is located, the insurance company can deny a claim. For example, if you bought a home with a finished basement, but later found out the previous owner did the work himself, and did not get permits or inspections, this may be a reason for denying a claim if it can be proven that the fire was started as a result of faulty basement wiring.
Every device is different, so you can't make a characterization that one brand or cycle or type does this and another does that. Mine goes through cycles where the power level is VERY low and it is not off. If you are currently doing it without a timer, and it works for you, don't worry about it. Mine requires one, as I don't want to do this processing in the panel and I use UPB for communications.RAL said:Yes, I understand that you are just measuring current. But from your earlier post, I got the impression that you needed the timer because you were detecting just the higher current draw of the heating coils, which may not be on 100% of the time. If the current switch has a low enough trip point so that it can detect just the motor, I wonder if you need the timer at all. Or maybe I misunderstood why you need the timer.
If you don't have experience with electronics and don't know the electrical codes, please hire someone else to do this for you that knows the codes and can follow them. You are working with high voltages. All modifications MUST comply with all electric codes. So yes, and insurance company can and will use that as an an out if you don't do it correctly.elvisimprsntr said:I wonder what a homeowners insurance company would say if it was determined your Rube Goldberg contraption was the cause of a fire which burned down a home, or worse yet caused personal injury/loss of life. My guess is they would claim homeowner negligence to avoid paying claims. Just because you can, doesn't mean you should.
