Hi,
I recently moved overseas and now have a dsl connection...I have alsways used the cable while in the US but am a little lost on how to setup correctly.
Got a modem from the provider and they put in the username and password in the modem setup and assigned the modem an ip of 192.168.1.1 Now with that I cannot use the WAN port on the router as that would not work. I connect the cat5 from the moden=m to one of the ports on the router and it works fine. The issue I have is how come I cannot use the WAN port and also once I do that I have to manually assign ip addresses for each device connected and get errors like I am using 2 gateway. I setup the router as ip 192.168.1.2 that was the best I could think of to make it work.
Now some devices I have to use the 192.16.1.1 as the dns and for some I have to use the DNS that the provider provided. Confused again.
Need help to streamline the setup. the connection is a dynamic ip connection.
Also, since the house is concrete I am using a wireless router on the first floor and an access point on the first floor. I have named them wirelessD and wirelessU. Is there a way for the device to automatically switch to the nearest wireless access point???
Thanks for your help.
regards,
regards,
