Piasa said:
I have 4 PIRs that work. And many window and door sensors.
If the 5800PIR communicates with the M1XRF2H, which translates and communicates with the M1, how can there be a compatibility issue? The H in the M1XRF2H presumably refers to "Honeywell", and the 5800PIR is Honeywell, so surely the two are compatible (he says with tongue firmly implanted in cheek). And if the 2H communicates correctly with the M1 for the other 5800PIRs, as well as the multitude of other wireless sensors installed, where could compatibility issues arise?
Speaking in general, anytime you have a protocol, there will be a data stream that has defined fields and acceptable values. It's common for a receiver to do some checking on the received data for validity. Sometimes, the checking that is implemented is more specific than it should be. For example, the person who wrote the code might check an incoming value against a list of values that current transmitters are known to send, rather than against the list of all allowable values. Then, sometime in the future, a new type of transmitter sends a valid, but unexpected value in that field, and things don't work.
Or, an untested type of transmitter might send a different sequence of events than those that have been tested, and that sequence brings out a bug on the receiving end.
In both cases, you end up with an incompatibility.
That said, since you say you have other PIRs (of the same model type?) that do work ok, I don't think you have an incompatibility issue.
Some possible causes that I can think of:
1. Even though you've replaced the batteries, replace them again. I've seen supposedly new batteries that are weak or bad more than once.
2. Check for dirty or corroded battery contacts on the PIR.
3. The PIRs have failed. Seems unlikely that two would fail at the same time, but not impossible. Here's a thread where
multiple GE wireless sensors failed. So it can happen!
4. Some type of RF interference. But it's hard to explain why it would affect just 2 sensors and not others, and why they would still fail when placed close to the receiver.
