Hi All
I have done a bit of searching, but can find nothing to help me.
I have an ELK M1, with the NX-448E-I Wireless receiver.
- Connected to this I have some NX450E-I, and as keyfobs the NX470-I
My problem is that as the receiver is a 48Zone unit, I programmed it in ELKRP as a 48 Zone system,
starting from Zone 49. - That works fine.
On the ELK keypad, it is also shown as being programmed correctly, ie, starting Zone=49, block of 48 Zones.
However, when I try and enroll anything on zone 65 and higher, it does not work. (On ElkRP)
- Enrolling it manually via the Keypad, I can only enroll up to Zone 64. Zone 65 and higher is not available.
The carton the NX-448 came in, says it is an NX-448 (48 Zone). Nothing on the PCB tells me what it is.
Am I missing something ?
Did the GE (UTC) agents I bought the NX-448 from, sell me a NX416, in a NX-448 box ?
- Could be possible, as the one Keyfob has a different Tx-ID that what the box says.
Any help with identifying serial numbers/part numbers etc, will be appreciated. Also if I am doing something wrong, and I need to activate the Zones higher than 64 with a diferent method on the keypad.
Regards
Riaan
Regards
Riaan
