apostolakisl
And Lou - if you were to just wire a jack with pairs that don't fit the standard, like just going pair by pair (orange white/orange, blue white/blue, green white/green, brown white/brown - for example) - my Fluke tester will fail the cable - it does matter, even at shorter distances - those twists are very important. As others said above, the standard has origins in Telecom so the ethernet standard was designed around this in the way that takes advantage of the twisted pairs. If you're making a 10ft patch cable it'll probably work - maybe not at gigabit; but if you're doing a 100ft run it will fail.
I am going to give this a try this weekend. I have a 60 ft patch cable and can easily pop a couple keystone jacks on the ends and swap the wires around any way I want.
Anyone care to take bets on how it will work? I'm betting it will work fine so long as twisted pairs are maintained, but perhaps be more susceptible to noise from nearby wires (which I won't really be testing) on gigabit mode.
