az1324 said:So the hub inside is basically a pogoplug w/ 256MB flash/ram. Which means it has more than enough resources to operate without the cloud. Also means there is a lot of open source software supporting it. The Lutron interface is a full subsystem with its own microcontroller and eeprom so Lutron probably provides this preprogrammed for assembly as to keep tight control over the code and functionality (Insteon also does this with Revolv). It may even have a similar serial API to their existing products.
But there is definitely potential to take control of this device and use it standalone as a Lutron bridge and maybe with open z-wave if someone is motivated to look into it.
http://www.cepro.com/article/staples_connect_vs_lowes_iris_home_automation_smackdown_at_ces_2014/As for technology, Staples is expanding its platform to include ZigBee, Bluetooth and Insteon-enabled devices, joining Z-Wave, Lutron ClearConnect and Wi-Fi as radios/protocols supported
http://www.pcmag.com/article2/0,2817,2454038,00.aspFuture improvements include manual Wi-Fi setup, plus support for Bluetooth, ZigBee, and Insteon wireless protocols. You won't have to buy a new hub when they become available; the additional radios will be offered as user-installable upgrades to your existing hub.
