Hi Guys,
I justy wantewd to know whether anyone else out there is using the HAI access control readers and finding issues with there operation at low temperatures?
I currently have 5 x access control readers that I have installed at my house and currently we are coming to the end of Winter here in Australia. I have identified issues with the outside readers (4 of) in that when the outside temp seems to drop below 7 degrees Celsius the readers to not read the access tags. One reader is at the front door but undercover and well protected from the elements yet when a tag is presented to the reader nothing happens. I have one inside the garage which never fails and I would (as a process of elimination) swap them over if the other 3 were not doing the same thing.
Any other time of the day these readers work and have worked so far for 2 years. The reason I have just found the problem is because we never needed to use the readers so early in the morning, we were always leaving for work not entering the house.
I actually now have someone come to the house three days a week to look after our 18 month old meaning they access the front door between 7 and 7.30 in the morning. This situation has only happened since my wife went back to work at the start of the year which means last Winter we never knew there was a problem because she was home.
I have emailed HAI International Support and at this stage, they have advised that they are investigating a similar report.
Thanks in advance
Trav
Oz
Thanks in advance
Trav
Oz
