I updated the links, sorry about that.
I have a 15 ohm resistor since I bought the 500 1/4W assortment pack, so I should be good to go.
<newbie>The transistor has 3 pins: collector, base, and emitter. Which pin connects to what?
Also, can I leave this project downstairs in my basement, and run 2 wires to upstairs where the LED is, or does it have to be close to the LED?</newbie>
The package shows that "Ic" is 200mA, is that the minimum required mA the VDC powersupply has to support? Last but not least, the package says Vebo = 6V, do I still have the right part (since you mention a 12VDC power supply)? Thanks
