Guy Lavoie
If you're using a digital multimeter, then it might be a bit harder to give you a foolproof answer. I'm assuming that when you see "1", you are referring to high resistance (ie: you would also see a "1" with the probes not touching anything). If your meter has a "diode test" or similar function, then use that to test the junctions. Basically, you would want a transistor to show a resistance value when one probe is touching the base and then you try both the emitter and the collector with the other probe, but then to show an open circuit when you reverse the polarity of the probes and do the same tests over again. Finally, you want to measure an open circuit when testing from collector to emitter regardless of the probe polarity.
