drozwood90
In case anyone is following the original topic, I have ordered the Square D interlock kit, $65 from my local Greybar.
Dan, that's awesome...you'll have to let me know how well that model works out.
--Dan
It's an older Briggs/Generac 5500W. I really only used it once for like 3 days during Hurricane Wilma. Did not run AC or anything like that. We had the fridge on it all the time, some fans, lights, tv and a toaster oven occasionally.I can tell you that UPB switches work fine on generator. At least they did for me for a few days during hurricane Wilma.Have you called the UPB manufacturer to see what they say about generators and their switches?
Steve,
Can you post details about your system / setup? What brand / model generator do you have? Are you running anything of size on your system...say and AC unit, or 220V Dryer...anything that might disturb the generator's output?
Thanks!
--Dan
Here is a power calculator to help with sizing if anyone needs it.
http://www.askmikeb.com/power.htm
I don't know where AskMike gets his information, but starting current on a table fan (2000 watts ???) is not 3x that of a space heater. And how can a 1/3 hp GDO use 250/350 watts while a 1/2 hp furnace motor is listed as 875/2300 watts?
Hi Bandido, welcome to CT!
I think that part # is just the cover. However, I believe it is very similar to my SquareD box, so the SquareD interlock kit should work. I just installed mine, and it was a breeze to install.
As for the cable, I paid $40 for a 25' spool @ Lowes, so that's not a bad price. I would also look out for the Lowes & Home Depot coupons, I have gotten 2 10% coupons in the last few weeks, helps a lot. If needed, sign up for the 'movers' package, they'll mail you a coupon.
