Ranger Digital
My god I thought texas was OUTRAGEOUS on kilowatts at 11.7 cents. YikeS!
Just so you guys know. I just loaded SageTV on an XPe machine at work and and it works just fine.IVB is right, you can't just throw any app on an XPe machine. Most XPe machines have only the minimum required applications/drivers/dependencies installed.
The Z-Troller is the 24 7 PC. This is a normal PC simply running XPe.I still don't get the value-add of the zTroller power-wise. Wouldn't you still need a 24x7 PC in your HA/HT setup somewhere? And if you have one, why not use that and not a zTroller? I.E., in the new world order, i'll have a single E6400 C2D running CQC Master Server/SageTV Server/FileServer/SQL*Server Express. The zTroller can't do all that, even if you could re-image the eXP. So if I'm going to have a PC run 24x7, why not just have the 1 PC?
1) I hate all of you non-CA folks. Enron is infamous for a reason. Check out the tiering structure below. Who actually uses only 300Kwh of power? I think the monastery near here is worse than that !
Baseline is ~300Kwh/month
Tier 1 (Baseline) - $0.11556
Tier 2 (101-130% of baseline) - $0.13139
Tier 3 (131-200% of baseline) - $0.22708
Tier 4 (201-300% of baseline) - $0.31555
Tier 5 (Over 300% of baseline)- $0.36190
$1000 seems steep for a 1.6 ghz celeron system with 40gb hd & 512mb ram. (yeah i know there's other stuff on it but still...)
wow. looks like tier 4 costs are up a lot from a year ago ( http://www.cocoontech.com/index.php?showto...amp;#entry25676 )
wow you people have cheap electricity! in northern cal:
baseline = 11.1 cents/kwh
101-120% of baseline = 13 cents
121-200% = 17.6 cents
201-300% = 21.6 cents
gas was $1.41/therm last month and will be going up, as will electricity rates since many of the electricity plants here are natural gas fueled.
That can't be right, is it? There must be more on there; i was pricing a mini-ITX system last night at LogicSupply, and got wound up cuz I was crossing the $500 mark.
Wow! What precious substance are they burning to generate electricity?
Oil?
:lol:
Signed,
Smug in Quebec ... where a nickel still buys you a Kilowatt-hour.
it is preloaded w/ HS software. http://store.homeseer.com/store/HomeSeer-C...ison-W13C5.aspx
