the 8" is back down to $79 and the 3.5" is $49, in store only.
<?xml version="1.0"?>
<!DOCTYPE cross-domain-policy SYSTEM "http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
<cross-domain-policy>
<allow-access-from domain="*" />
</cross-domain-policy>
Thanks. I have put a crossdomain.xml file in the root of my server: http://10.0.1.4:8081/crossdomain.xml:
Code:<?xml version="1.0"?> <!DOCTYPE cross-domain-policy SYSTEM "http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd"> <cross-domain-policy> <allow-access-from domain="*" /> </cross-domain-policy>
Still the same results with that. I also tried to put it in the same directory as the configuration xml with the same results. Is that what the crossdomain.xml should look like?
for referrence, how long can i expect to see the configuring screen before it loads?
I had an idea for your Panel Builder app. Add the ability to put set a button's action to be a different configuration xml file. Then when the button is pressed it would render that screen. This way you could have multiple screens with more control and navigate between them easily.
<button type="menu">
<btncolor>0x555555</btncolor>
<btnborder>0xffffff</btnborder>
<labelsize>17</labelsize>
<btnwidth>60</btnwidth>
<btnheight>30</btnheight>
<btnx>250</btnx>
<btny>35</btny>
<label>NewXML</label>
<labelx>125</labelx>
<labely>30</labely>
<labeloffsetx>0</labeloffsetx>
<labeloffsety>0</labeloffsety>
<action>http://192.168.1.2/test2.xml</action>
</button>
