Here in the laundry room installed 1 4 foot indoor/outdoor LED tube fixture purchased from Amazon two years ago. (September, 2016)
Years now updating the main laundry room lighting...going from an incandescent two lamp fixture to a standard 2 tube 4 foot flourescent lamp to current 4 foot single strip florescent tube like LED fixture.
Initial intent was to install multiples of these in the garage.
4ft 36W 5000K IP66 - Daylight
Paid $32.39 for these.
For the garage I would go with an 8 foot / 2 meter version of this lamp. (old old garage had 4 rows of sets of 3 8 foot double florescent tubes)
What I used to test in the garage were multiples of these lamps which are way bright. You cannot look at them as they are too bright.
Daylight in the garage with these and great to work on my automobiles.
Duttek LED Ceiling Lights, 120V 18W 36 LEDs 6500K With 3 Magnetic Legs Neutral /Daylight White, Round Flush Mount Light at $11.99 each in September, 2016. 3 of these around the GDO spaced in a triangle around 5 feet from the GDO on the ceiling.
White white pure daylight piecing lamps. For under hood and under car work DIY'd Cree 12VDC 20 watt LEDs which also are very bright and do not get hot. These are the same size as the old halogen on stands (well replaced them) for painting et al.
