Desert_AIP said:Ok now that I know you have HLC enabled:
The status tracking you describe is working correctly.
When you send an off command, the controller assumes the unit turns off and changes the status in the system immediately.
But it also verifies the result, so after the preset UPB delay, it sends out status requests to all the units in the room and updates the actual status received.
This is why you are seeing the status change and go back. The lights aren't really turning off.
Do you know if the two lights are on the same phase or opposite phases?
Does this behavior (not turning off when both are on) happen always or intermittently?
Does it matter which light was turned on first?
I assume you are using room OFF commands.
Verify in Upstart that the Room OFF link is actually programmed to 0%.
Do the switches respond to any of the other Room scenes (A, B, C, D) when both are on?
In HLC, the Room Off command is really a link Activate with the responses programmed to 0%.
Try sending the Room Off Link as a Deactivate command from the UPB link section (use the same link number but send it as an OFF command rather than an ON command).
desert_aip,
To answer your questions:
1. Not only is rm1-2 and rm1-3 on the same phase, they are also on the same breaker.
2. The issue happens intermittently. But definitely more on the side of not working rather than working.
3. It does not matter which light is turned on first, I can still experience the problem of them not shutting off.
4. I am testing using the touchscreen->control->rm1 (Exterior Lights)-> OFF/ON. I also try with SNAPLINK with the same results.
5. I have not tried any scenes, A,B,C,D, but I put my switches in setup mode and then tapped bottom rocker 3 times (told to me by HAI tech) to put them in non dim mode. That's because the courtyard rm1-3 is dimmable LED. but the breezeway rm1-2 are non dimmable CFL. So I believe the scenes won't work as they basically affect the dim level. One thing I will be trying tonight is to replace my rm1-2 non dimming CFL's with dimming LEDS, putting the switches back in dimming mode (setup and then tap top rocker three times..told to me by HAI tech) and then retesting.
For the other questions, I have to wait until my 232 connector and cable get in on Wed so I can connect with upstart.
Again...I really appreciate the help.
Mike
