Taking the laptop and connected CIM around to various outlets, I was getting readings on the "noise meters" of "0", and the text said signal strength is 'excellent' and noise level is 'none'. At that point, UpStart would control all 3 light sets normally, but LTe would only control 2 of them reliably, and the one that was unreliable had the highest signal strength (Beachside Porch, Unit 28)
I began to question further whether the problem was noise or something else when I tested entering commands directly from the console, and found that sending link commands from the console controlled all 3 sets of UPB lights normally. But sending via PC Access still was erratic.
But then I came to an embarrassing realization. I had originally set up an Omni II board and when it failed a few years ago, I replaced it with an LTe. I did not, however, download a manual for the LTe and left everything set up like it was on the Omni II and just put the UPB switches in the "B" house code (Units 26, 27, 28) along with X-10 switches. Both A and B house codes were set to "Extended".
As I read the LTe manual last evening, I was chagrined to find the statement that X-10 and UPB can coexist on the LTe system, but only if they are on separate house codes. So today, I changed the house code format for the "B" bank (Units 17-32) from Extended to UPB.
I am waiting for the program to run tonight and see if the control is any better. But I am puzzled that if I look at the console and select to "Show" programs, the only UPB command that shows up is #16...no sign of the commands for the links to the 3 sets of lights...
1. WHEN AC POWER OFF
THEN HOURS AC OFF ON FOR 3 HOURS
2. WHEN HOURS AC OFF OFF
AND IF AC POWER OFF
THEN AC OFF ALARM ON FOR 2 SECONDS
3. TIMED 15 MINUTES AFTER SUNSET MTWTFSS
THEN UPB Outside Front Porch ON
THEN UPB Outside Garage Lights ON
THEN UPB Outside Beachside Porch ON
4. TIMED 10 MINUTES AFTER SUNSET MTWTFSS
THEN SET LIGHTING LEVEL Entry Hall Sconces TO 20%
5. TIMED 10 MINUTES AFTER SUNSET MTWTFSS
THEN SET LIGHTING LEVEL Kitchen Island Light TO 40%
6. TIMED 10 MINUTES AFTER SUNSET MTWTFSS
AND IF DAYLIGHT SAVING LIGHT FLAG IS INACTIVE
THEN Great Room Sconces BRIGHT 3
7. TIMED 15 MINUTES AFTER SUNSET MTWTFSS
AND IF DAYLIGHT SAVING LIGHT FLAG IS ACTIVE
8. TIMED 22:00 MTWTFSS
THEN SET LIGHTING LEVEL Kitchen Island Light TO 20%
9. TIMED 22:00 MTWTFSS
THEN Entry Hall Sconces OFF
10. TIMED 22:45 MTWTFSS
THEN Kitchen Island Light OFF
11. TIMED 23:00 MTWTFSS
THEN Great Room Sconces OFF
12. TIMED 15 MINUTES BEFORE SUNRISE MTWTFSS
THEN UPB Outside Beachside Porch OFF
THEN UPB Outside Front Porch OFF
THEN UPB Outside Garage Lights OFF
13. WHEN ALL ON
THEN ALL UNITS ON
14. WHEN ALL ON
THEN UPB All Outside Lights ON
15. WHEN ALL OFF
THEN ALL UNITS OFF
16. WHEN ALL OFF
THEN UPB All Outside Lights OFF
There is likely a simple explanation, and maybe you will be able to see it right away. I appreciate your patience with someone who must seem hopelessly challenged. :mellow:
