Hi All,
We got a new project for integrating RTI home automation. One of the existing systems which we need to integrate with is HAI Omni Pro II. I am not experienced with HAI but am a very fast learner
So far we've been able to successfully integrate and communicate with the security system (using 2-way driver)
I am in a bit lost with the lighting and thermostats. I installed the PC Access and downloaded the configuration from the Omni Pro II but can't see any used entries on the Units page or Thermostats page. The list of (254) dimmers just show the default settings and so is the thermostat lists
Since the ViziaRF is RS232-to-Zwave adapter I assume the programming was done in the ViziaRF rather than in the OmniPro.
My questions are:
1. On the Omniport Pro II, top left corner there are 5 RJ45 jacks then space and then 2 more. The ViziaRF is connected to the 4th RJ45 from the left. How do I know which serial port is this? The Serial page in PC Access shows 6 serial ports
2. What type of module do I select? Omni-Link or Pro-Link?
3. Once the ViziaRF+ is programmed with the dimmers (it is currently programmed and working) how does the OmniPro make references to each dimmer?
Any help would be greatly appreciated
EK
My questions are:
EK
