Hello,
I have been spinning my wheels over trying to get my IP cameras on my Omnitouch 7 keypads for the last couple months and had given up on it since I tried everything. I noticed tonight there was an update for the Omnitouch 7 Keypad (Version 1.12). I downloaded it and hoped it would have resolved my IP camera issue, but it didn't. I discovered this website and saw a handful had helped with getting IP cameras working. I tried several suggestions that were made to other posters, but I was unsuccessful. So maybe someone out there can help me out.
I have an
Omni II panel with
Omnitouch 7 keypads. I have a
Honeywell NVR (
http://www.honeywellvideo.com/products/video-systems/recording-devices/nvr/performance-series/797971.html) and
4 Honeywell IP Cameras (H2D1PR1). The cameras can be viewed through a web browser, but requires a plugin.
I have configured the sub stream on these cameras as follows (see below).
Code-Stream Type: General
Encode Mode: MJPEG [Other options H.264 and H.264H]
Resolution: D1 (704*480) [Other options CIF (352*240]
Frame Rate (FPS): 20 [Other options 1-20]
Bit Rate Type: CBR [Grayed out, unless Encode Mode is selected with H.264 options]
Bit Rate: 2048 [Can be customized]
On PC Access, I have tried every single option on FPS(1-20), Quality (Low, Medium, High), Resolution([320*240][640*480]), and including a username and password as well as leaving it blank.
For the address, I have used the IP of the camera (
http://192.168.1.201) and I have also tried using the cameras RSTP string(rtsp://admin:
[email protected]:554/cam/realmonitor?channel=1&subtype=1)
I have confirmed this string is working through VLC player.
Any suggestions?
