kurtisdigital said:Hey Tigers -
I got my Arduino to communicate with my OP2 via the serial port, using the "pro link" protocol and just sending ASCII text messages back and forth.
This is not nearly as cool as what you were trying to do but it's a bit better then tying the two together using relays / zones / outputs / etc. One issue is that you are of course limited to 120 some odd text messages in the OP2.
pete_c said:Here will remove one serial connection on the OPII and connect it to my Quatech serial to IP server to make play sort of virtual.
I think the baud rate was 9600 8 N 1 eh? Pro-link set up on panel for connectivity.
pete_c said:As the panel is three floors down; its easier to connect to a serial server for me to play with.
I have set up communications this morning and just need to validate my RS-232 connector. I might go to a 6 pin cable with a new made up RS-232 to RJ-45 device.
I'll try and pm him.pete_c said:What else do I need to do?
@kurt
Can you post your stuff here?
I don't get it. Why RJ 45?
