OpenHab and OmniPro
I'm not sure if this will be of any help to you but to install the Omnilink bindings, you first have to install the MarketPlace plugin which is Addons->Misc->Eclipse IOT MarketPlace. This will download a lot of bindings including the Omnilink binding which can be found under Addons->bindings.
picta said:
I was able to connect to the panel and get most of the items, but no units. Tried a couple of times, with the same result. Were you able to get units automatically or do they have to be created manually?
You'll need to add your units manually in the "things file".  There's an example entry for a "Thing Unit" in the sample file I posted.  UPB units get picked up automatically, but it seems generic "Units" currently do not (bug).
The Omnilink binding issues are reported and tracked here:  https://github.com/QuailAutomation/openhab2-addons/issues
I am really surprised no one ingenious has created a things export / importer.  Doesn't seem terribly impossible with Haiku Helper exporting devices.....
