Bad battery would also come under suspect. If the panel is in alarm, it'll draw the extra power from the battery. If the battery is too small, aux power too close to the limits and what have you, could give the symptoms of an AC failure....or if the transformer is undersized or has an issue (assuming Elk) and PTC protected, possible issue combined with above.
