Hey guys, running into problems installing the .NET service. As you can see in the below it appears to be using the .NET Installation utility Version 2.0.50727.832 that is included in the HAILogger V1.0.8 package. When I tried to install using the included install.bat file I get the below. As you can see below this error problem HAILogger.exe is working as it should and providing the appropriate output.
Likely a rookie problem I'm experiencing here. Any quick fixes, or duh moments that could quickly get me up to speed?
___
C:\HAILogger>install
C:\HAILogger>InstallUtil /LogToConsole=true HAILogger.exe
Microsoft (R) .NET Framework Installation utility Version 2.0.50727.832
Copyright (c) Microsoft Corporation. All rights reserved.
Exception occurred while initializing the installation:
System.BadImageFormatException: Could not load file or assembly 'file:///C:\HAIL
ogger\HAILogger.exe' or one of its dependencies. This assembly is built by a run
time newer than the currently loaded runtime and cannot be loaded..
___
C:\HAILogger>hailogger
INFO: CoreServer: Starting up server 1.0.8.0
INFO: WebService: Listening on
http://0.0.0.0:8000/
INFO: CoreServer: CONNECTION STATUS: Connecting
INFO: CoreServer: CONTROLLER IS: OmniPro II (4.0B)
INFO: CoreServer: Retrieving named units
INFO: CoreServer: Unsolicited notifications enabled
VERBOSE: ThermostatTimer: Added to watch list Family
VERBOSE: ThermostatTimer: Polling status received for Family
VERBOSE: ThermostatTimer: Added to watch list Living
VERBOSE: ThermostatTimer: Polling status received for Living
VERBOSE: ThermostatTimer: Added to watch list Porch
VERBOSE: ThermostatTimer: Polling status received for Porch
VERBOSE: ThermostatTimer: Added to watch list Garage
VERBOSE: ThermostatTimer: Polling status received for Garage
VERBOSE: ZoneStatus: 16 TS-INPUT, Status: SECURE
VERBOSE: ZoneStatus: 69 MS-HAL-S, Status: SECURE
