DoItMyself
Please ignore the post above, the sensors were damaged in some cases but the wiring appears okay for the most part. I have gone over each sensor in the house (each wire) to test for continuity. Some window sensors had been cut or were missing so I will need to replace them. Someone in the past had used the smoke alarm wiring to connect a window sensor in the upstairs master bedroom which is interesting. The lines themselves appear in good condition. The only sensor that I had issues with was the sliding glass door sensor, pictures below. Is that a pressure sensor? Magnet? I tried applying pressure to see if that closed the circuit as well as using a magnet and neither produced a tone.
I have, no surprise, a couple of questions. First, if someone is using hubs like wink or nest or even a home automation controller, what advantage is there to using something like an Elk that integrates it all, would this mean someone would not use the wink or nest apps and would use the security app as an interface?
As we begin other renovations, cost is a bit of a concern, I am not sure how much tinkering I will do over the next couple of years and as Ral mentioned in another thread it might be good to get the 20P for now and who knows, maybe something newer and better is out there if I really start getting more into HA. On that note I am wondering if the 20P would be enough for my uses. Should I look at the 21ip?
I am going to need to add wireless sensors. Both to windows, a door, glass breakers, and smoke alarms. Would this affect which panel is easier to install and connect? Also I would like to use one of the less expensive monitoring services while also receiving remote alerts (and depending on complexity, is remote access/arming possible?) How would the Vista 20P be for these requirements?
Thanks so much for your help.
[sharedmedia=gallery:images:1047]
[sharedmedia=gallery:images:1046]
