Bushy said:Q) As per Haiku, my Temperature sensors show on the Security Screen which is a bit annoying as there not security zones and don't show any info. Can you either only show zone types that are security and/or add an option to remove unwanted zones.
You can hide items by removing the short name in PC Access, uploading the names to the controller and then refreshing the configuration in Space (using the top right action menu on the home screen).
Thanks for advising the trick to hide items. I'm using this method for timers & flags used by my HAI controller that mean nothing to the user. The only issue for Temp & Humidity sensors is they need to have a short name to show on the 'Climate' screen.
Would it be possible to only show 'security' type zones or don't show zone types 81 to 85?
Zones have config data that allows the programmer to know if they are temperature, thermostat, humidity, aux or security. It shouldn't be a problem to have only the security zones show up in the security area. Removing the short name should not be required.
I am currently looking to get Space, and although this wouldn't be a deal breaker, it would be a real annoyance to me.
