dontheo said:
I think there are a lot of assumptions here that are incorrect. If you are looking inside the panel and see a resistor, it most likely strapping off the fire zone supervision. That is what I understood was the case. If ther is other WIRING attached to zone one, you have a big problem.
As far as the rest of the EOLs they don't matter in a home system. Typically we use them in commercial UL systems for supervision of the equipment during the day. An example would be a customer of a retail store tampering with a door contact so that it will be bypassed at night when the store closes. As for residential, the only resistor that matters is the fire zone. It would be imprudent to not check this as one is dealing with life safety.
In Texas, we see ADT giving away free smoke detectors all the time and disconnecting the original smoke detectors because they lost their fire alarm license in Texas at one time. Most franchise companies I have come across do not have a fire alarm license or the training to understand what they are doing.
Ted, CCP
NICET LEVEL III
Texas Fire Alarm Planner and Superintendent
Critical Infrastucture Endorsement
I explained the reason why zone 1 would be strapped off. Doubtful it's to bypass fire supervision.
Resistors make a difference, but the law of diminishing returns comes into play. 3 state zone wiring with multiple cables, home runs, or similar, the overall value is diminished. 4 state wiring would be specified if you really are concerned about cable integrity, which is the purpose of the EOLR, not necessarily tampering, which would mandate installs to meet the tighter specifications (DOD) which would have a tamper switch installed at every junction, multi-state supervision, balanced switches and minimal exposed cabling or armored cable below a certain height, in addition to 24H supervision of the cable and contact points themselves.
NEC dictates code for the remainder of the installation. Plenty of articles and workmanship standards to meet in that document that are typically always not met, both by novice and plenty of EC's combined.
As far as what you see, it's no different than the mom and pop companies and there's no distinction between national, dealer or independent installers. What you may see in your area is subjective....I've seen just as many independents perform poor installations or integration.
Dave
NICET IV Fire engineer
Former tech support, Notifier/Honeywell IS
NICET CCTV, A,B,C
Multi-state LV and FA contractor
DOE/DOD non-proliferation certified
SCIF/Top secret cleared, DOD
Multi-vendor certified
Current position unimportant.
