Hey all,
I have a M1G in my home that was present when I bought it, and during the last 5 years or so I've had to try to figure out what components I have and how they are configured. Anyway, I say this because I have no idea exactly what components were originally installed, but I've been able to figure out most of them, I think.
Most of my zones are hard-wired, however I do have a wireless zone expander (M1XRF2G) which runs the zones for my front door and 4 other window zones that were evidently difficult to hard-wire. I believe this was all installed in 2007 when the original M1G was installed, and so the batteries are likely that old. (I haven't changed them and they seem to still work)
I've also had an intermittent issue with the front door sensor (recessed door contact type... i.e. sunk into the frame) where occasionally it will read violated (I open the door), but when I close the door it doesn't return to non-violated. This is obviously a problem since it has caused my alarm to go off on a couple occasions when I've armed it on the way out the door, and I wonder if it could be a low battery issue, although as I understand it the control should indicate some form of low battery trouble if that were the case...
Anyway, I've recently been exploring adding things like glass-break sensors, motion detectors, control-connected smoke detectors (my existing are just the 'dumb' type), etc. So since the RF2G seems to be quite old, I've found it difficult to find much info about it, and what types of sensors might be supported. (GE sensors, I think?) Also, given my front door intermittent problems, I am wondering if it is smart to invest more money in the existing system, or would I be better served by upgrading to the Two-way wireless system. The main attractive feature would be the fact that sensor events are seemingly confirmed, and so I would not need to worry about intermittent connections. (I would hope) However, the sensor choices for the two-way wireless seem quite limited.
Obviously replacing everything with the two-way wireless would be quite expensive, but if my existing setup is truly obsolete, I wouldn't mind getting with the latest and greatest.
Thoughts?
Thoughts?
