Hi Im about to install an ELK M1 in UK and have question about supply power.
. Have searched forum etc and found old post from Spanky
"...In reality you can power the M1 from a separate DC power supply. Run 13 to 14 volts DC into the battery leads. Run a +13 volt wire from the +Battery input to one of the AC inputs so that the M1 will startup when the power switch is turned on. "
My question is can the M1 take a direct DC input to the AC feed (so I can keep Battery backup). Have looked at the board and it appears to have a standard bridge recertifier to convert the AC input. So DC should go straight through - no?
Thanks for any advice
Jim
Jim
