I have most of my smokes/heats run. Used 2WTA-B detectors and 5601P for heat only.
I found a set of wiring diagrams for this combination, located here: http://www.systemsensor.com/pdf/bulletins/modulewiring.pdf
I want the maintenance signal to go to a separate zone (since I have the room), so that narrows it down to Figure 1 or Figure 2. From there, Im not sure. Do I use Output 3 as the relay (as in Figure 2)? If so, Im reading it as jumping the aux power + from the board to one side of the output3 relay. Is that correct?
Or is there already power going to one side of the relay so I dont need to jumper it in? I just didnt want to do something and "let out the smoke" as they say.
Finally, when I wire it to the panel the System Sensor diagram shows 2 EOLRs but doesnt give a value. Am I to use the value that the panel requires? Or is there a different resistor that is required.
Thanks in advance.
-Chris
Thanks in advance.
-Chris
