I've been fiddling around with Premise to control my zwave system, and so far it's been much more stable than the other options I've tried, and I like the overall layout of the builder application.  However, there are a couple little things that I'd love to find a way to modify, so if anyone has thoughts on how to approach the changes, I'd appreciate the advice:
MiniBrowser: I would love to make it so that I can alter the state of a light switch from the main screen, instead of having to tap the light, turn it on or off, then tap the home button. Would any of you have thoughts on how to do this? I've been working on swapping out icons and creating a CSS that would modify the theme, but am not sure how to change the button behavior. Any thoughts on where I might start looking for that behavior?
ZRTSI: I have Somfy RTS shades, and am using their ZRTSI z-wave interface, and the shade shows up as a dimmer - it appears to work with the on/off status, but is there any way I could add a "stop" signal?
Thanks in advance for any advice, and if there's anything else I should be aware of, definitely let me know!
