I'm in the process of installing a few SA UPB switches this weekend. The first two went smoothly; one US2-40 to control the living room cans and a US11-40 for the porch lights. This my first foray into UPB so I was feeling pretty positive after getting them installed and setup with UpStart. Then my 3-way install knocked me down a peg. I have an existing 3-way circuit; a switch at the bottom and top of the stairwell. The top box has the load wires. I am replacing both switches with US2-40s. What I decided to do, and please tell me if this doesn't make sense, is to wire the two switches in parallel (neutral-to-neutral, line-to-line). The switch in the box with the load wires is the one that will actually switch the load, so the brown wire on that US2-40 is connected to line wire going to the light. I also connected the existing red wire (3rd connector for the traditional 3-way) between the two switches using the wht/red wire on each. I got it all hooked up and the top switch works as I expected - the bottom did not. I went into Upstart (first time for either of these two switches) and set them up and got the bottom switch to work, but only by enabling Rocker1 to transmit. That seems to work. Based on my limited knowledge of UPB, it seems that this only works because a) UpStart magically knew to create a link between these two and b) this link is sending UPB messages telling the other switch what to do.
So I have a couple of questions:
1. Is there any way to have the bottom switch actually use the red wire to tell the upper switch to turn on/off instead of using links? I don't mind that it works the way that it does, but I want to better understand the wiring for UPB. It seems like those remote wires should work, but perhaps not between two US2-40s?
2. The bottom switch has no load on it and I capped the brown wire with wire nut. I'm still a little nervous with live wire in the box. Is there a way to shut off load in control so that the brown wire is never live? I didn't see this option in UpStart.
3. I'm using UpStart without the wizard. Is it normal that it tries to guess the links you want? It went a little crazy and created links I had to then go remove.
Thanks for the all the help via the various UPB threads. I wouldn't have gotten this far!
