Here's a picture of the error I'm getting for reference.
http://postimg.org/image/50sluspbd/
Also, controller logs:
2014-02-22 20:57:06 HaikuHelper v4.03 starting up…
2014-02-22 20:57:07 ControllerNameHere: Initializing scripting environment…
2014-02-22 20:57:08 ControllerNameHere: Applying controller script…
2014-02-22 20:57:08 Starting HTTP service on port 9399…
2014-02-22 20:57:10 Sync » Starting forced sync operation…
2014-02-22 20:57:11 Notification » ControllerNameHere: Connection to controller established
2014-02-22 20:57:11 Notification » Push » ControllerNameHere: Sending push notification: Connection to controller established
2014-02-22 20:57:11 Sync » ControllerNameHere: Syncing stage 1 of 5: Clock…
2014-02-22 20:57:12 Sync » ControllerNameHere: Syncing stage 2 of 5: Controller Configuration (Reading Configuration)…
2014-02-22 20:57:33 Sync » ControllerNameHere: Syncing stage 3 of 5: Controller Configuration (Loading Objects)…
2014-02-22 20:57:34 ControllerNameHere: Unhandled exception in script on line: 77 in function "onSyncStart": Can't find variable: getTimeFromTimestamp
2014-02-22 20:57:34 Sync » ControllerNameHere: Syncing stage 4 of 5: Controller Configuration (Saving)…
2014-02-22 20:57:34 Sync » ControllerNameHere: Syncing stage 5 of 5: Rain Advisory…
2014-02-22 20:57:35 Sync » Rain Advisory » ControllerNameHere: Precipitation for Sat: 0.0mm
2014-02-22 20:57:35 Sync » Rain Advisory » ControllerNameHere: Precipitation for Sun: 0.3mm
2014-02-22 20:57:35 Sync » Rain Advisory » ControllerNameHere: Precipitation for Mon: 0.1mm
2014-02-22 20:57:35 Sync » Rain Advisory » ControllerNameHere: Precipitation for Tue: 11.2mm
2014-02-22 20:57:35 Sync » Rain Advisory » ControllerNameHere: Precipitation for Wed: 1.0mm
2014-02-22 20:57:35 Sync » Rain Advisory » ControllerNameHere: Setting "RainAdvisory" flag to 12mm…
2014-02-22 20:59:01 ControllerNameHere: Unhandled exception in script on line: 77 in function "onSyncStart": Can't find variable: getTimeFromTimestamp
2014-02-22 20:59:06 ControllerNameHere: Initializing scripting environment…
2014-02-22 20:59:06 ControllerNameHere: Applying controller script…
2014-02-22 21:00:07 Sync » Rain Advisory » ControllerNameHere: Setting "RainAdvisory" flag to 12mm…
In both of the above, I've removed the controller name as it's my actual last name. You can see at initial startup (20:57:34) the error is present, as well as for any subsequent synchs (20:59:01). At 20:59:06 I clicked the "Run Script" button, and at the next sync (21:00:07) there are no errors.
